Hi
Using Vault Professional 2014.
I am trying to add user properties to dwf file with no luck. I created a user property and can change for other filetypes but not dwf.
Are all DWF files locked for editing on user properties????
The DWF file is not a visualization file of a dwg file.
with regards
Hallgrimur
If the dwf file is not a visualization... where did it come from. This may have some bearing. I am able to edit UDP's on a dwf file that is a visualization.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi
The dwf file is created from a dwg that I don't have. A contractor created the dwf that I then put into my Vault. I can't either change the data for visualization DWF nor dwfx files.
with regards
Hallgrimur
I was able to to this when I was testing Vault 2013 Collaboration AEC
with regards
Hallgrimur
I have to be perfectly honest... I don't know why this is. It works just fine here, and I haven't been able to find any settings that specifically cover properties on dwf files. On your first post... look for a button that says "Need an Answer". This will escalate your question to tech support guys,... hopefully one of them knows something. Sorry.
Chris Benner
Is it not at the bottom of the message?
I'm not sure it's on every post.
Are you a subscription customer? You can contact tech support directly for help.
Chris Benner
we are a subscription customer but I have not been able to send support requests. I am defined as an End User. I will check my CAD manager if he can change that somehow.
I dont have a button like that. Wish I had
with regads
Hallgrimur
Ok, sorry about the button... I thought everyone could see it. 😞
Good luck with getting a support case in for this.
Chris Benner
I think that button just an option for the EE's, so AutoDesk doesn't get bombarded with requests.
That seems reasonable.
Regarding this case I finally managed to send a support case and got the response that they can confirm this behavior and a change request has been logged for future release/servicepack.
So I am left with no results and out implementation of Vault is at a standstill.
regards
Hallgrimur
Well, ain't we special! 😄
Chris Benner
That is not good news my friend, sorry.
Chris Benner
Autodesk knows of this error and as far as I know this will be addressed in the next hotfix.
Fingers crossed.
with regards
Hallgrimur
