Dave,
I believe the DWF publishing has a limitation in that it will not publish
DWFs for IDW files when using Add Project. Please double check the readme
file, but I think that is still an issue in Vault 4. So, you might decide to
add project (remove the IDWs temporarily) and then check them in separately
as a workaround.
Bob
"Dave Hoder" wrote in
message news:5077057@discussion.autodesk.com...
When doing an "Add Project" all files got a dwf as expected except for 3
idw's. Does anyone know what might cause this? Also, auto-published dwf's
don't show an attachment in VE top pane but manually attached files do. Why
is this? The auto-published files show in the view pane when you click on a
parent part but the manually attached ones don't.
Dave Hoder
Product Design Engineer
idX Seattle
www.idxcorporation.com
Using Inventor v10sp3a / Productstream 4.5
