I created a complete new set of start part and assembly templates as well as different size drawing templates. With these templates I setup data cards in the vault that have specific properties that feed the new drawing templates.
These all work fine when a new part or assembly is created using these new model templates. When I fill in the data cards on the models the iproperties populate as well.
Now comes the problem. I have older files created using the old start part and assembly templates and when I fill out the data cards (which this part is no issue) not only do the iproperties not populate, but because of this the values do not populate in the drawings as well.
Anyone have any ideas as to why this is? And how to resolve it?
I would really love to hear some feedback on this. If this is posted in the wrong forum please tell me.
Maybe it needs to be posted in the vault portion.
For the drawing which uses old template needs to be updated using new drawing template. Please check out all the old drawing files, run “Drawing Resource Transfer Wizard” to update the title blocks and then verify that the iProperties from the part gets populated in the Drawings’ title blocks. Then you may check in the drawing files.
Hope this helps.
Hi Madhanagopal,
Thanks for getting back to me.
I tried this wizard tool and I am not seeing how this will fix my issue. This only deals with drawings.
My issue is with model templates (old vs new) Models created with new model templates using the data cards
populates the new drawing templates. Models created prior to the new model templates using the old model templates do not populate the new drawings created using the new drawing templates. This is the issue.
When I look at the old models after filling out the data cards, the iproperties are not filled out or have they been created. I end up creating them and filling them out manually. I am trying to find an easier solution that fixes this so that whether it is old or new models they both automatically populate the new drawing template.
I hope this makes sense.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Don't worry about it. Just glad you did.
I will take a look at it tomorrow. We as a group are meeting to try and dela with some of these issues.
Sorry to be a pain, but any chance you can post a screen shot of the exact setting you are speaking to here?
Here is the screen snapshot.
