Aside from this, it's certainly a bit "scary" to think about database calls
to be made across a WAN. I think I'd rather see the remote file store on a
WAN before I'd want to see SQL calls made over a WAN, given the frequency of
the respective accesses.
It may be worth a test to see what you're in for, but I'm not overly
optimistic...
Also, to follow up on something you (Michael) said:
"with the ADMS, the Vault database, and File Store on our LAN...."
Do you really mean this? Where would the database physically reside?
Jeff
"Ajay Choudhary"
wrote in message
news:5131955@discussion.autodesk.com...
ADMS installed on the same machine as Microsoft's SQL Server is the Autodesk
supported configuration.
But you can work with a remote SQL server instance. This is achieved by
changing certain server configurations.
Suppose you have a SQL server instance [named REMOTE_INST] on a machine
[named REMOTE_MC]
Install your ADMS on a separate machine [named LOCAL_MC].
Then update the web.config and Vault Manager Config file to change the
database instance name to REMOTE_MC\REMOTE_INST
If the above instance has sa password different then default sa password for
AutodeskVault instance, VaultManager will prompt to provide that.
Then launch Vault Manager and create KnowledgeVaultMaster and Vaults. They
will be created at the remote instance.
I'll suggest to create AutodeskVault instance on the REMOTE_MC with default
sa password.
There are certain limitations and workaround associated with attach/detach
and backup/restore. Also full content search will not be available.
So if you really need it contact Autodesk technical support.
I do not know if there are any published documentation for this or not.
Ajay Choudhary
Software Engineer
Autodesk Inc.
"Michael Trull" wrote in message
news:5131908@discussion.autodesk.com...
Does the Autodesk Data Management Server (Vault Server) have to be installed
on the same computer as Microsoft's SQL Server?
The reason I ask is our company has Microsoft's SQL Server Enterprise
Edition installed at cthe ompany's data center which our division accesses
through a WAN link. We considered putting the ADMS at the data center, but
decided against it due to the performance hit imposed by checking files
in/out through the bandwidth bottleneck created by the WAN link. So with the
ADMS, the Vault database, and File Store on our LAN, IT is wondering if SQL
requests (calls?) can be made to an SQL Server on another computer through
the WAN link?
As always, thank you for your help!
Sincerely,
Michael
