I have a user group setup in Vault for non-engineering users. This is mainly for sales and service so that they can see/use the Vault information and not be able to edit the files. The Vault permissions for the group is "Document Consumer". Per the Vault help page, the permissions for this group would allow "Read-only access to files and folders only, including the job server queue".
Vault is a pretty "smart" application, so why then does it ask the vault user if they want to "check-out" a file when they are opening from Vault?
If they say "Yes", then they are greeted by yet another dialog telling them that they can't check it out because they do not have the permissions.
Does that even seem right that they are even asked these questions? Remember, Vault knows what group they belong to and what permissions they have.
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 337.88)
INV Pro R2015, (update 2)
Vault Pro 2015
Kirk,
I doubt you'll get a good answer on "why" here. This may be a good candidate for the idea station however:
http://forums.autodesk.com/t5/vault-ideastation/idb-p/2
You'll probably want to generalize it (since this situation comes up in other locations in Vault) and site this as an example E.g. "a user should not be presented with an operation they do not have permission to do"
- Matt
