Is there a quick way for the Vault administrator to disable the creation of any dwf for "DWG" files only? If the DWF doesn't exit then DWG True view will launch which gives our non CAD users better access to more accurate measure and publish commands.
Yet we still want dwf files create for all other Inventor file types. I was wondering if there was setting in the JobProcessor Config file or other file.
CraigH
Hi CraigH,
If you are using Job Processor:
find C:\Program Files\Autodesk\Vault Professional xx\Explorer\JobProcessor.exe.config, remove following line:
<jobHandler class="Autodesk.Vault.DWF.Create.dwg" handler="Connectivity.Explorer.JobHandlerDwfPublish.DwfJobHandler, Connectivity.Explorer.JobHandlerDwfPublish" />
Then, this job processor won't pass swf creation job for dwg.
If you are not using job processor,just make sure not create swf file when check-in.
