Vault Pro 2013; I have a Temp Vault that resides under my overall Vault, it's failing during a "Backup" function. It is 1 of 6 that I'm trying to backup.
If I Detach that particular Vault & run a Backup on the system; Will it bypass that Vault and do the rest?
Yea if that Vault isn't attached it won't backup, although if it's 1 of 6 that it failed on... chances are that there's an underlying issue there which will still fail on. Give it a go but it could be a permissions issues, attach the backup log here if it continues to fail.
This depends on how the vault is detached. If someone detached it in SQL then definitely a problem - as the database would be expected but missing. If detached from ADMS console then the vault would be entirely removed from the system. So this could solve backup issues if there was some specific problem with that database.
Paul
I did the detach from ADMS because the errors appeared in a specific Vault. Unfortunately when I re-ran the Backup/Restore, it crashed out again....
I think we have some serious SQL error....I've inquired with our AutoDESK Help team for support.
