Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Default Vault check-in status
5 REPLIES 5
Marcel_
426 Views, 5 Replies
since our new Vault setup all files we check into Vault for the first time are checked in with status "obsolete" (for models) or "released" (for drawings).
I thought that I now understand the Lifecycles since I assisted in the setup, but this seems strange to me and I cannot find where to change the default check-in status for files. I'm sure there must be an option. Could you please help me out?
thanks!
Marcel
5 REPLIES 5
cbenner
in reply to: Marcel_
First thing we need is.... what version and flavor of Vault are you setting up?  That could make a big difference.
But it seems this is probably due to category assignments.  Category assignment rules can force a new file into a certain category.  These categories are then assigned to a specific lifecycle definition, and in that definition the file will take whatever is set as the default state for new files.
Marcel_
in reply to: cbenner
hi Chris,
I am setting up Vault professional 2014.I am not sure what you mean by flavor?
Yes exactely, we are using category assignments (that I did not set up myself). Could you please indicate where I find these default states for new files within the category Assignments?
thank you!
Marcel
smithmat
To set the category that gets assigned to a file
  • Tools->Administration->Vault Settings->Behaviors->Rules
  • Change top combo to "File Rules"
  • Here you can change the Default rule for category assignment or create a new rule
To set what lifecycle the file gets put in based on the category:
  • Tools->Administration->Vault Settings->Behaviors->Categories
  • Choose the category.
  • In the bottom Behavior pane, click "Assign"
  • You can add Lifecycles to this category as well as set the default Lifecycle definition for this category.
To set what the intial state is for a lifecycle defintion
  • Tools->Administration->Vault Settings->Behaviors->Lifecycle
  • Pick the Lifecycle definition you want to change
  • Click edit.
  • In Lifecycle Details pane right click on state you want to be default and choose "Set Default"
Hope that helps,
- Matt
Marcel_
in reply to: smithmat
Hi Matt,
wow thanks for this very helpful overview. When adapting the lifecycles last time I went from top (work in progress) to bottom (obsolete / published) and just by editing these last, they were automatically set as standard.  🙂
thanks again,
Marcel
cbenner
