We are using Vault Professional 2013. When we release files by changing the state to Released, the Enter comments: field at the bottom of the dialog box defaults to "Released to manufacturing". Can this default phrase be changed or left blank?
Solved by BLHDrafting. Go to Solution.
I think you can edit the default Comments and/or turn them off through here.
Brendan,
In the words of Ed McMahon, "You are correct, sir!"
Tools, Administration, Vault Settings, Behaviors tab, Lifecycles... button, select Basic Release Process, click on Edit..., select Released state, click on Comments tab, select Released under Comments, click Edit... (again), change comment to your liking. <whew>
It sure is going to be nice to have that taken care of. Now we'll see how long before anyone notices.
Thank you!
