style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman','serif'; mso-fareast-font-family: 'Times New Roman'">
face=Arial>
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">You
are not killing two birds :-). But, I just wanted to suggest a solution that
would work for you. With the recommended settings for get latest version, you
will not loose the modification that you had made.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">Regarding
"Open from Vault" option, you won't get a prompt to check out. Other than that
"Open from vault" will work as expected.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">Let
me try to explain here.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">When
you open a file from vault actually we are using the following
commands.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">1.
Open from Vault - Downloads the file from vault if it was not available
locally.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">2.
Check Out - Reserves the file to the current user
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">3.
Get latest version. - Replaces the local files to match the version in the Vault
server
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">So,
in the Invisible Vault settings, I suggested using "No" and "Never
Prompt" for “Check Out the file when Opening it from Vault”. This means,
the second action in the above list will not work. In other words, you will not
see the option to Check out the file when it is opened from
vault.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">The
other option about "Get latest version" is also "No" and "Never prompt". This
means, when you open a file, it will not overwrite the files that were already
edited and saved in local disk. However, it will replace the older version
files. This is intentional as this would help the users to see the latest files
always.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">If
you wanted to explicitly replace the locally edited files, you can use “Undo
check out” with “replace local copy”
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">Hope
this helps. If you have any further questions, please let me
know.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">Regards,
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'">Madhan
commands.
locally.
server
vault.
face=Arial size=2>
always.
face=Arial size=2>
face=Arial>
know.
face=Arial>
face=Arial>In Inventor Vault Browser, you may notice that some of
the files with "Red" status icon. This means, the file in the local disk is out
of date. For example, you opened an assembly, and one of your colleagues has
checked out a part file, edited, saved and Check In to Vault. You may want to
see the changes that your colleague had made. So, typically, you use Get latest
version on the top level assembly or on the part file. When you do this, the
local copy will be replaced with the latest version in the vault.
face=Arial>
face=Arial>In short, you may call the files with RED status
as "out dated file"" or "older version
file"
face=Arial>
face=Arial>There is no hard rule that you need to
use "open from vault". But if you consider the advantage of seeing the
latest information, you would prefer to use "Open from
vault"
face=Arial>
face=Arial>Regards,
face=Arial size=2>Madhan
face=Arial size=2>
