Hi tphan2k,
Would you consider using 'Autoloader' to do batch upload?
rgds,
Chear Huat.
"tphan2k" wrote in message news:5985443@discussion.autodesk.com...
> I have the same problem here with Vault 2008. I have about 18,000+ DWG to
> be put into vault. This problem shows up when using Task Scheduler. The
> DWGs were created from DXF using AutoDWG program. As you can see, it's not
> efficient when you have to open all 18,000+ DWG manually and check them
> into Vault. Anyone have any suggestion?
