i am handing over a property from vault to a title block attribute in Autocad. The property in vault is from type "date".
In Vault the value just shows the date (e.g. 27.05.2011), but in Autocad the value shows the date AND the time (e.g. 27.05.2011 08:30:22). I would like to have the value without the time in the title block.
Is there a possibility to format the date value in Vault so that it just stores the date value without the time? Is it possible to format the value during the property sync? Would it be better to format the value in Autocad (and not in Vault)? How (do not know a solution for this kind of attribute definition in Autocad)?
Thx for any advice,
klaus
It looks like the time is always getting written back. I have logged this with the development team.
Could you use a text property instead in Vault? You lose the date picker when editing properties through the Vault client, but you'll get the correct formatting (users woudl have to enter the corract date format in vault).
Did you ever get this to work? I am trying to map a UDP (user defined property) from Vault Collab to an autocad created block attribute. This block is inside of an Inventor.dwg file. Are you using an Autocad generated titleblock within an Inventor dwg also??
Cheers,
Dave
no, we are not using ACAD titleblocks within Inventor DWGs...But there is the possibility to map properties from vault to Inventor DWGs...
klaus
Hi, is there an hotfix in preparation to change this behavior? The advantage of a date UDP, is to perform search like: Older than a specific day, the last 10 days, etc...
Or is there a way in Autocad to format this date?
Hello
Is there now solution known?
I' ve checked, if the attribute can define the format. But Vault seems to be the master.
Greetings Daniel
Do you have some news? This behavior is not acceptable. I consider this as a bug!
We are on Collab 2012 and this problem persists. Can anyone tell me if this deficiency is still in 2013?
Dave
Nothing change in 2013. Same behavior.....
And there is something I discover:
-Create an UDP as text.
-Map it with a Autocad titleblock.
-Map it with an Inventor iProperty as date.
-Change the iProperty date and look at the result in the UDP.
Almost all of our customer it's the Swiss format dd.mm.yyyy, but by a specific customer it's the American format mm.dd.yyyy. Why? Nobody can said me why. I already try to change regional settings, SQL collation, etc... No change.
How to fix this new strange behavior? By fixing the original problem describe in this thread: Link a UDP as date with an Autocad titleblock must display ONLY the date no time.
Hi sirs,
Any idea about creating an autocad property, but deleting X characters from another field?
In Inventor is possible.
Regards
Anyone have any updates on this? It is still happening for one of my customers in the 2016 software, using Vault Pro, Inventor , and AutoCAD. See the attached screenshot!
This is a story going on for several years. The only thing you can do right now is to map the UDP unidirectional from ACAD to Vault.
There are even worse things happening. If you create a drawing in daylight saving time and the time is changed to wintertime, the date will jump by one hour meaning for example from
07/06/2015 00:00:00
to
06/06/2015 23:00:00
when you do a synchronize properties in Vault.
The priority support told me that this is fixed for Inventor with the next updates, for AutoCAD there is no timeline yet.
We had an improvement in Vault 2018.2 Update to have a setting to enable only show Date without Time in the Title Block.
That's great, but what if you cannot upgrade to 2018? Will there be an update for Vault 2017 to fix the issue?
I am having this issue still in version 2019 of Vault professional used with ACADE 2019.
Could you tell me how to make this setting where date datatypes will show only that in titleblocks and not date + 0.00.00 ?
Thanks!
