So I inherited the maintenance of the Vault at my company and I am confused on steps 5-8 on the Vault server update for a single site. Specifically when it says to navigate to the installed location of connectivity.admsconsole.exe in a command prompt. How do I go about this? Any help would be appreciated.
Solved by herrerh. Go to Solution.
Open a command line Windows:
Start -> Run -> CMD.EXE
Navigate to the installation directory
cd C:\Program Files\Autodesk\ADMS <version> 2014\ADMS Console
If you are using Vault basic, omit <version>, otherwise place Workgroup or Professional instead.
Browse to the directory if you are unsure of the exact path.
-Hywell
Thanks!
I was having trouble navigating to the location but I must have just mistyped something in the cmd prompt.
