Vault has a web services API; this allows a custom Vault client to use the
Vault server. There are minimal documented ways to otherwise interact with
the Vault from within a vault-enabled application: for example, in AutoCAD
(yes, I know you said Inventor) you could use the VAULT command-line.
It sounds like you may have some rather specialized requirements; you might
consider contacting Autodesk directly for more specific guidance on your
particular situation.
Dan
wrote in message news:5148356@discussion.autodesk.com...
I am not very familiar with vault so needed a quick view on following
scenario.
If we are to develop a custom application on some Autodesk product and if we
also wish to use Vault along with that product, do we need to take any
additional care in designing/developing the custom application. Does vault
offer any programming interfaces/APIs? Does custom app really need to bother
about the existing integration between the vault and the base product?
Thanks in advance.
