Hi there,
Vault Pro 2012
Looks like I am having an issue when I create a custom view filter at the very top level folder (project explorer) as follows:
Property: Name
Condition: Contains
Value: .DWG (that is dot dwg)
This works only in top folder. Does not propagate to many subfolders and that is critial for what I need to do.
Is there something else I need to add in the filter area? I need all the files (*.dwg) from all the subfolders that contain drawings to list.
Thanks and I hope I was clear.
Mike
Solved by User01_acad2010. Go to Solution.
Thanks everyone, but nevermind
Looks like I can type *.dwg in the search box when on top folder and it will list all the .DWG from all the subs.
