I have been looking at custom objects in Vault Pro 2013 to track our documents to our customer. I am very close in nailing down the process in how this would occur but I have a couple of questions on custom objects..
1. Is there a way to link a certain item revision (not always the latest) to a custom object/instance and have it maintained? Meaning a document or drawing could've gone out at rev A to the customer but before its approved we are making revision B. So in this process the custom object/instance would still have revision A linked and not updated to revision B.
2. Is there a way to hide all of the custom objects and only have them shown for certain people? Meaning when the project is completed/shipped I want to hide it or hidden from people who are not part of the project team. Granted I can hide the information under the custom object using the security but I want to hide the custom object in the navigation pane as well.
3. Is there a way to run a report on the entire custom object scope and not based on a given instance level?
Regards
Vault Pro 2013 Service Pack 1
Hi there,
Unfortunately I do not believe there is any way to lock the item release to a custom object - the link is maintained to the live object, be it file, item, Eco or other custom object and as such will update. I can suggest perhaps looking at adding notes or a document detailing revisions Though this is quite manual.
In terms of access to custom objects take a look at the Access Control List available in the custom object configuration dialog - here you can set overall permissions for access to an object type. This would allow you to block users from the object type.
I may need more information on this last point but you should be able to create an advanced search that covers all custom object types and generate a report from these results.
Hope this helps,
