I'm new to Vault. I have post a couple posts:
Now I'm close to chose custom object as the solution. now I have question:
I create a custom object, name as Task, copy some drawings and paste as link.
1. Next I change the Task's category to Engineering for example, now I hope all the drawings under it will change to the same category, Engineering, automatically, how I can configure it?
2. After that I change the Task's state to WIP, same thing, all the drawings under it should change to WIP automatically, how I can configure it?
3. At the end I will do my job on all the drawings and release them when I'm done. once all the drawings are released, I hope this Task's state will change to released automatically, how I can configure it as well?
4. I plan to add some UDP, User defined Properties, to the Task. e.g. 'Client ID', 'Client KPI Days'. 'Client KPI Days' will depend on 'Client ID'.
Client ID = A, Client KPI Days = 5;
Client ID = B, Client KPI Days = 7;
Client ID = C, Client KPI Days = 11;
how to store this kind of lookup information in the Vault?
when user input the Client ID information, how I can populate the Client KPI Days according to the lookup information automatically?
5. In the future, new Task instance was created, I like to have a custom dialog box to
5.1 fill all the information like, Client ID (which will fill Client KPI Days), and others.
5.2 Change Category according to UDP Type. If Type = "CAFM", then change category to CAFM; if Type = "CAD", category will be CAD, ...
Is those possible? I'm going to start from reading DECO and programming with custom object by Doug Redmond.
Any help I appreciated it very much.
Thank you,
Wes
