This may sound simple, but how do you create revisions in Vault that will drive revision numbers in Inventor part and assembly files? I'm able to have the part/assembly revision numbers show up in Vault under "Rev Number" but now I need Vault to drive the Revisions, not Inventor.
Solved by licensing. Go to Solution.
So after some reading, I realised that the revision field should be initially populated automatically when a file is created and checked in to Vault. My problem is that I just upgraded to Vault Workgroup and was trying to do all these revisions with files that were first created in Vault Basic.
I hope this helps others avoid the same mistake!
