Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Creating Vault Revisions
2 REPLIES 2
licensing
419 Views, 2 Replies
This may sound simple, but how do you create revisions in Vault that will drive revision numbers in Inventor part and assembly files?  I'm able to have the part/assembly revision numbers show up in Vault under "Rev Number" but now I need Vault to drive the Revisions, not Inventor.
2 REPLIES 2
licensing
in reply to: licensing
....So I've found how to update the "revision" field in Vault using the life cycle definitions and release processes, but mine won't update when I change the "state". I think it might be because the "revision" field is not initially populated in Vault. Does anyone know how to populate that field?
licensing
So after some reading, I realised that the revision field should be initially populated automatically when a file is created and checked in to Vault.  My problem is that I just upgraded to Vault Workgroup and was trying to do all these revisions with files that were first created in Vault Basic.
I hope this helps others avoid the same mistake!
