Vault General Discussion
sabuj.saha
Message 1 of 7 (488 Views)
Create new property for a File in autodesk Vault 2012 in VB.net
488 Views, 6 Replies
08-17-2012 11:46 AM
I am wanting to create a new property for a file in vault. I could not find any code sample to start with.
Any idea how can I do it...
Do you have the vault api help file?  You should be able to search that and see:
AllowedMappingDirection Enum
Summary
The allowed property mapping direction values.
ValuesNone
Read
ReadAndWrite
Write
Also, if you use Visual Studio you should have intellisense that would show you the options...
FarrenYoung
Message 2 of 7 (430 Views)
Re: Create new property for a File in autodesk Vault 2012 in VB.net
08-23-2012 11:10 AM in reply to: sabuj.saha
Hi Sabuj,
You will likely get more results in the Vault Customization forum.  You are in the general forum.
http://forums.autodesk.com/t5/Autodesk-Vault-Customization/bd-p/301
Have you seen the AddPropertyDefinition function on the PropertyService class?
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
FarrenYoung
Message 3 of 7 (420 Views)
08-23-2012 11:22 AM in reply to: sabuj.saha
I found the following via www.google.com
http://adndevblog.typepad.com/manufacturing/2012/06/add-user-defined-property-by-vault-api.html
--Farren
sabuj.saha
Message 4 of 7 (418 Views)
08-23-2012 11:23 AM in reply to: FarrenYoung
I found that after I posted this thread...
Thanks For the link...
sabuj.saha
Message 5 of 7 (414 Views)
08-23-2012 11:34 AM in reply to: FarrenYoung
The property mapping in that example is write.. I am needing a property that will do both ways.
Do you know how that can be done?
Regards
Sabuj
FarrenYoung
Message 6 of 7 (409 Views)
08-23-2012 11:39 AM in reply to: sabuj.saha
Summary
ValuesNone
Read
ReadAndWrite
Write
--Farren
sabuj.saha
Message 7 of 7 (405 Views)
08-23-2012 11:42 AM in reply to: FarrenYoung
Thanks you so much..I will try that and get back to you on that....
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
