Hello, i tried update Vault 2013 with newest update. It was succesfull and then the Vault want from me migration of databases thgough ADMS. But when i try it it will show me this windows with this error. What can i Do? I have 4 times mor free space on disc then the SQL data so this can't be the problem...
Could not allocate space for object 'sys.sysobjvalues'.'clst' in database 'Vault' because the 'PRIMARY' filegroup is full.
Thx for help
Solved by minkd. Go to Solution.
It sounds like either the drive where the SQL databases are located is full, or you have reached the size limit of SQL Express.
If its the latter, and you are currently using SQL Express 2008, you could upgrade to SQL Express 2008 R2 since the limit increased from 4GB to 10GB in SQL Express 2008 R2. If you are already on SQL Express 2008 R2 and have reached the 10GB limit, then you have to purchase a supported edition of SQL from Microsoft.
-Dave
Hello Dave,
thx for response. It will not be the full HD because we got 3 times more free space than is needed. And the full SQL? The SQL got more than 4GB but it was fine before updating of Vault, so i thought that it can't be it...
So i try reinstall SQL to R2 and we will see. Thank you very much Dave.
Only the mdf files have the 4GB limit, the ldf files do not count. And the limit is per database so the total of all your mdf's can exceed 4GB.
The migration requires requires space in the database so it will not succeed if your database is close to the limit prior to the migration.
Make sure you download the 32-bit version of Microsoft SQL Server 2008 R2 Express Edition (SP1). I'm not sure but it might even be on the Vault Server Install media.
-Dave
