I've got an .iam that is ran through iLogic. I have this vaulted as a template. What I need to be able to do is copy design the .iam then rename it and also have it rename all the part contained within the .iam.
For example my .iam template name would be "15-1-0000 - ASSY" and each part in it would be named "15-1-0000 - PART".
When I design copy it I'd want to be able to do something along the lines of change the .iam name to "15-1-0001 - ASSY". And when I do that I would need each part to do a save as and have the name update to "15-1-0001 - PART".
In what way can I accomplish this? I'm clueless and anything would help, I need this done by Friday...
Solved by cbenner. Go to Solution.
When you do the copy design you will need to rename all of the part files as well as the assembly. You CAN use a Find & Replace to do this, but as far as I know there is now automatic way to rename the assembly and have the part files rename themselves from that.
You can also use Find & Replace on the destination path, if you need to.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thank you,
That sounds like it should work just fine, thank you. Now my question is though if in the original .iam I have a rule that’s referring to something such as:
Parameter("15-1-0000 - GUARD_HOLDER:1", "WIDTH")
When the files become renamed from “15-1-0000 – GUARD_HOLDER:1” to “15-4-6548 – GUARD_HOLDER:1” how can I make that rule adapt and update to locate and use the new file as its source part? OR will the Find & Replace function change these aswell?
