Using the Copy Design in Vault a lot.
Now I'm trying to exclude the library files in the list, those never have to be copied.
However, when I edit the Settings the 'Include library files' are grayed out (see attachment).
Why is that? And is there a way to change that?
It would be great if I don't have the library files in the list, much quicker.
Thanks in advance.
Cees
The option 'Include library files' in setting dialog can't be modified.
If library files are set to Copy with Ctrl click, You can right click the assmebly file, apply command Reuse Library Files from context menu, then all Library Files under this assembly will be set Reuse.
Hope it helps.
Sorry for the late reply, but it's been a mad house here 😉
Thanks for the reply, though for me a better option is to use Folder View (first tab).
Content Center files are the placed under one folder name. Now I only see the custom files that I have to rename, exactly what I needed.
I'm new to Vault2012, could be it was also like that in previous versions, but discovered it recently.
Thanks again.
Cees
