If a job has been copy designed is there an easy way to find out what job it was copied from? Thanks for any help you might be able to give.
Solved by olearya. Go to Solution.
If you look in the comments of the new file it should detail what file and file version it was copied from.
I need to know the jobs that were copied designed from 2 years ago. After the newer job has been manipulated and changed. Can someone please help me figure this out? I thought one of the big reasons for having vault is to be able to track your job from start to finish.
I have templates that has changed and I need to know what jobs used the old templates so they will not be copy designed in the future.
Sorry - I am confused - you cannot go through the historical comments to find this information as I have suggested?
You are correct I got confused because one of the guys working here wrote over the comments with his information. Thank you. You were correct.
Thanks again for your help.
