Recently we scheduled a meeting with a customer to talk about Vault Professional. He asks something similar to "Copy Design" functionality.
Let's say I have a folder structure with the files like below;
*800 represents the main folder and 800-001 to 006 represents the subfolder.
What I want to do is, I want to set this structure as a template and like in the "Copy Design" functionality, I want to create a new folder structure based on the template with a different prefix. (Lets say the folder and subfolders name should start with 801 instead of 800 and)
Is it possible?
Cheers,
Volkan
Solved by volkan. Go to Solution.
With the out-of-the-box Vault Professional, this is not available. You could create a folder structure, then have 'placeholder.txt' files within the folders.
If you are an Autodesk Enterprise Support account, you can purchase the 'Enterprise Add-on' which includes the 'Clone Folder Structure' functionality.
http://download.autodesk.com/us/vault/Enterprise-Add-On-for-Autodesk-Vault-Guide-2014.pdf
You can also look in the App Store for Vault. I think there's also an app for it. Otherwise check the site of Doug Redmond, JustOnesAndZeros, in the past he had also an app to copy a folderstructure with properties and ACL.
Mark
Actually we can do it with the brand new Vault Data Standard. 🙂 Here is an explanation in the cool orange's website;
http://blog.coolorange.com/2014/10/17/create-folder-tree-from-a-template/
