Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Copy Design deletes part number property
10 REPLIES 10
Message 1 of 11
eucci
937 Views, 10 Replies
We are using copy design and want to retain original part numbers while creating new filenames.  If we check "update part number for copied parts" the new part number will be updated to match filename (we don't want this).  If we uncheck that box then all the newly created parts will have an empty part number property which we also do not want.  There does not seem to be a way to retain original part numbers when using copy design.  We consulted tech support from our reseller and their installation exhibited the same behavior.  Is there a fix for this or work around?
Thank you
Eric
Inventor suite 2011 64 bit
build 535, R:2011 SSR
Vault Workgroup 2011
build 15.2.66.0
OS Name    Microsoft Windows 7 Professional
Version    6.1.7600 Build 7600
Other OS Description     Not Available
OS Manufacturer    Microsoft Corporation
System Name    OFFICE6
System Manufacturer    System manufacturer
System Model    System Product Name
System Type    x64-based PC
Processor    Intel(R) Core(TM) i7 CPU         960  @ 3.20GHz, 3201 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date    American Megatrends Inc. 0813, 5/25/2010
SMBIOS Version    2.5
Windows Directory    C:\Windows
System Directory    C:\Windows\system32
Boot Device    \Device\HarddiskVolume1
Locale    United States
Hardware Abstraction Layer    Version = "6.1.7600.16385"
User Name    OFFICE6\ERIC
Time Zone    Eastern Daylight Time
Installed Physical Memory (RAM)    12.0 GB
Total Physical Memory    12.0 GB
Available Physical Memory    8.74 GB
Total Virtual Memory    24.0 GB
Available Virtual Memory    20.3 GB
Page File Space    12.0 GB
Page File    C:\pagefile.sys
10 REPLIES 10
Message 2 of 11
Kenny
in reply to: eucci
Thanks for your post.Smiley Happy
As far as I know, the behavior is as design, if you uncheck the "update part number", the part number will be set as empty. Seems there is no workaround for this. You can edit the properties by yourself.
And if you have suggestion, please contact your reseller, thanks.
Message 3 of 11
josephcooley
in reply to: Kenny
This is a terrible design.  I was so excited when I found copy design that I wouldtn ahve to get files from the vault and then use autoloader then rename them in vault and then check out again before I started working on my project.  This would be perfect if they would just leave the part numbers alone.  Has there been any updates in 2012?
Message 4 of 11
achintam
in reply to: josephcooley
Thanks for the feedback.  This will be addressed in a future release.
Message 5 of 11
wilfried_schratzer
in reply to: eucci
this problem is already existing (I'm working with Vault Prof. 2012, Update 1)!
Did anybody know a workaround now?
At what release will this bug be fixed?
Thanx!
Message 6 of 11
In Vault 2013, if you uncheck update part number, the part number property will maintain its value instead of being blanked out.
Scott Mollon
Quality Assurance
Be sure to check out the Vault Help Wiki!
Message 7 of 11
josephcooley
in reply to: mollons
This is going to save me so much time thanks for the update
Message 8 of 11
in reply to: eucci
hello,
i have this bug also in Vault 2012.
There is now a hotfix for Vault 2012 to fix the bug?
Thanks in advance.
greeting
eddie
Message 9 of 11
mollons
in reply to: eucci
Currently there are no plans to change this behavior in Vault 2012.
Scott Mollon
Quality Assurance
Message 10 of 11
josephcooley
so is this changed in 2013?
Message 11 of 11
mollons
As I mentioned in the post above: Yes.
Scott Mollon
Quality Assurance
