Vault General Discussion
Valued Contributor
92 Kudos
Post 1 of 3
Copy and paste files into Vault
203 Views, 2 Replies
01-11-2012 09:08 AM
I noticed that we can copy files from windows explorer then click paste in the edit menu to add files to Vault folder, but this does not work for design files, dwg, ipt, etc, the paste menu item is greyed out. Why? Is this designed as is?
Product Support
11 Kudos
Post 2 of 3
Re: Copy and paste files into Vault
01-11-2012 09:38 AM in reply to: smilinger
Hi smilinger,
CAD files MUST be added to Vault via the CAD application Vault Add-In.
I hope this helps.
Ron Smith
Front Line Technical Support Specialist - Data Management
http://help.autodesk.com/view/VAULT/2014/ENU/
http://crackingthevault.typepad.com/
http://underthehood-autodesk.typepad.com/
Employee
12 Kudos
Post 3 of 3
01-11-2012 10:13 AM in reply to: r.smith1
I would like to add on to Ron's answer a bit. It is definitely recommended that you use the add-ins to add your data to the Vault. The reason being that you want to maintain your file relationships so the Vault can manage them. Adding files directly to Vault Explorer will not achieve this.
Also, the copy/paste command is available from inside the Vault Explorer application. Meaning that you can copy a non-design file from inside VE and paste it in a folder in VE.
For copying files within the explorer client, use the copy design command as this maintains your file relationships.
Hope this helps,
Adam
Adam Luttenbacher
Sr User Experience Designer
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
