Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Content Center: Upgrade from Basic 2012 to Pro 2014
6 REPLIES 6
tahdesign1
289 Views, 6 Replies
I am about to upgrade from Vault Basic 2012 to VaultPro 2014.
There are 3 servers that will be involved to get where I need to go:
  1. Original Vault Basic 2012 Server (Production Server) running Server 2008 (SQL Express)
  2. New Temp Server the same as the Production server to use as a pass through (Server 2008, SQL Express)
  3. New Server for VaultPro 2014 running Server 2012 and SQL 2012 Standard.
Through several other ng threads I have come up with the following path:
  1. Install Vault Basic 2012 of temp server, install Vault Basic 2014 on Pro Server
  2. Take a backup from Production Server and restore to the Temp Server (2012 Basic to 2012 Basic)
  3. Upgrade Temp Server from Basic 2012 to Basic 2014
  4. Take backup from Temp Server Basic 2014 and restore to Pro Server Basic 2014
  5. Upgrade my client base to 2014 looking at the new Pro Server running Basic 2014
  6. Once the dust of client upgrade has settled, Upgrade Pro Server from Basic 2014 to Pro 2014
So the one question I have left has to do with the content of the backups being used.
I have never done any customization to any of the standard content (content center).
Because of that I have never included that in my backups. I would assume in this upgrade process I could also ignore the standard content.
6 REPLIES 6
herrerh
in reply to: tahdesign1
Im seeing some steps that you don't really need.
You could easily do the following:
2 Servers, the current production and then the future production server.
Backup using the ADMS Console on the production server.
On the future production server install Vault Basic 2014 and desired version of SQL.
Copy backup to the Vault Basic 2014 server and restore.
Upgrade Vault Basic 2014 to Vault Pro 2014.
You're right that you do not need to include the standard content in the backup unless you plan to still use Inventor 2012.  Otherwise you can install the Inventor 2014 standard content after the restore.
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
tahdesign1
in reply to: herrerh
Thank you,
As to the Standard Content I guess my question should say that will 2012 designs that have used the standard content (none have been customized) be able to find it's content from a newly installed 2014 Standard Content. I assume by your answer that this is the case.
As far as my steps were concerned, I added the extra server to breakup the amount of things being changed at once.
If I took a backup from my current production server and restored it to the new server it would be going from Vault 2012 to Vault 2014 AND SQL Express 2008 to SQL Standard 2012 all at once.
So my intent is to move to Vault Basic 2014 with SQL Standard 2012 on the new server and then upgrade my client base to 2014 looking at this before going to Vaultpro.
However, I have spent a lot of time updating my setups (templates, styles, etc) and am also changing some directory structure with my Vault. Because of that I wanted to restore a 2012 backup to 2014 (basic to basic) and do a bunch of testing. My intention was to do the testing on the temp server but I guess I could do it on the new server IF I can wipe the restored Vault from it when I am truely ready to move the client base up (since production would have still be going on during the testing).
herrerh
Once you've created a content center part from the standard libraries it becomes a part (Library) within vault.
Hywell Herrero
Product Support
Autodesk, Inc.
tahdesign1
Thank you for the reply but it makes me needed to clarify what that selection means when scheduling a backup.
  1. Does in mean that it will back up the Standard Content Source. The Libraries that are on ADMS. Which I assume you would want to do if you had customized these in any way (I have not).
  2. OR does it mean it will backup the libaries of the Standard Content that have been produced as people use them in a design. I assume that if you opened a design that the Standard Content part files do not exist for that it would just then be replicated from the ADMS Library.
I read through the help files and they are not clear on whcih one this setting is talking about either.
Please see the attached image to better clarify what I am asking.
herrerh
This means that Standard Content shown ADMS as libraries (not the library folders you see in the Vault client) will not be backed up.  Custom libraries will still be backed up.
As people use parts, they become actual parts in the Vault library folders which are seen from the Vault client.
Hywell Herrero
Product Support
Autodesk, Inc.
tahdesign1
Thank you.
