Hi All,
Just noticed an abnormal functioning on LMtools License usage with Vault Professional 2014 in our Client Environment. We Logged into Vault with Vault Client 2014 but when i perform Status Enquiry from LMTools installed on Vault Server, It displays 0 License in use..
Any idea or Hotfixes?
Balaji A
It's possible that a Vault license does not get consumed by the ADMS until something is actually accomplished in the Vault itself. The client does not obtain the license. The ADMS server does. Try actually using it and double-check.
DarrenP, anything to add?
what does the flex lm log say?
it should be grabbing a license when you log in to the vault client
if you logging into the the ADMS console it does not consume a license
DarrenP
In certain circumstances a license already checked out will run other instances e.g. multiple sessions of Navisworks only consume 1 license. Could this be a case of a Suite-based product license already signed out be re-used?
