logged as an admin, I have assigned single ipj file for all users. Tools>administration>vaultsettings> "Enforce consistent Project file for all clients"
Does this still require the users to mannually set the project file in the inventor? I see that the current project is not the same as what I assigned thru administration.
Yes. You still need to set your project in Inventor. Because this Consistent Project file setting is only for Vault Clients and not for Inventor. Client will use this Administrator set Project for commands like Move, Rename, Copy Design, etc.
Me too!
We are using a single projetct with Vault 2014.
Please make this an option, to check that the clients are using the same project as the vault.
-At present, It changes on the clients to default.ipj every 2nd or 3rd day
I agree with you. Can you please go and log this at http://forums.autodesk.com/t5/Vault-IdeaStation/idb-p/2?
Thanks.
Thanks CAD-One! I'll try this out, though, I'm interested in if this works every time with opening files from inside vault. -will be testing it 😉
When a project is chosen Inventor should not choose another one or make a default, that's just my opinion, but the workaround is good for now
I posted a request for the option.
This is a message which pops up frequently when I start Inventor as described above:
which iI find very strange.
And consequently I cannot load anything from Vault. -When I check from inside Inventor the project file is set to the right one though 😞
This message comes up if you do not have the project which you used last. If you have deleted the used project then this will come.
Also this message comes up if you start Inventor after doing Vault operations like Copy Design/Move/Rename etc - which downloads the project to TEMP folder and deletes it after the operation is over.
Inventor Team is fixing this issue.
Thank you for the reply Senthil.
I only have one project, which is in the root of my working folder, and it does not go missing when I check in files. My Vault settings are:
And it is selected in Inventor in the project menu...
Looking forward to the fix for this 🙂
Do you see this message after performing any vault operations that I mentioned earlier? If yes then it is known as I mentioned.
You can get more information on this thread on the fix and its availability
http://forums.autodesk.com/t5/Inventor-General/Inventor-Proect-File-Missing-Message/td-p/3933137
