The property compliance is updated whenever a change is made that would cause a property value to change (checkin, change lifecycle, etc), or if the compliance rules for the property definition is changed.
-Dave
Why could be fail?
We have done a sincronize propertis and keep the mistake, just with a check-out, check-in it runs.
regards
What version and which vault product are you using?
Also, what do you mean by "compliance evaluation failed"? Is it that it is showing non-compliance, or is the compliance check failing with an exception? If it's the latter, then can you please post the server vlog that contains the exception?
-Dave
During Property Compliance evaluation if an internal exception or a SQL error/SQL down error occurred, the entities being evaluated for compliance will be marked as "failed". This should be rare and happen infrequently.
Property Compliance will next be evaluated for these entities on the next Check In or when a Property Definition is modified that it used by these entities.
If you are seeing "failed" property compliances (as opposed to "Non-Compliant") frequently you should contact Product Support.
