is there a column (setting) to show the folder of a file?
The use case would be to perform a search across many folders and subfolders that brings up a result of many files. In this search result i want to see the folder name (or workspace path) for each found file. I did not see a column matching this information.
Is there a setting/column for this?
In case needed, I use Vault Collaboration 2011.
Thx,
klaus
Solved by alan_ho. Go to Solution.
Hi Klaus,
You can customize the main grid to include the 'Path' field.
This will allow you to view the folder location in the vault.
Hi Alan,
thank you for the quick response, but I can´t find a field called "path" in the available columns if i choose to expand my view of the grid (I right click the columns in the grid and use the command for customizing the view).
I think it should make no difference that i use the german version of vault collaboration 2011? (i searched for other columns that could be translated for "path" but still no match).
klaus
Klaus,
My apologies for I missed out your environment.
The 'Path' field is only available in Vault 2012.
The 'Path' or 'Folder' field cannot be displayed in 2011 out of the box.
