I've deployed Extensions to the following directory, C:\Documents and Settings\All Users\Autodesk\Vault 2012\Extensions. Is this correct? I've been to successfully test one of the extensions on a test server, but the 2nd Extension gets a "Error loading extension ..." message.
This works locally fine, I'm able to run both Extensions without issue, but when it gets moved to the test server problems. I also have custom built binaries that are shared in both Extensions folder.
