how if i check out file (excel) than in working folder the file is deleted,
can i check in back that file ?
or do you have solusion to restore that file to the vault?
Thank you very much before,
Solved by Senthil_Kumar. Go to Solution.
Even if you delete the file in local disk, the file still should be in Vault. So you should be able to download the file again using Get/Check out command from Vault Client. Once you download the file, you can again modify,save and check-in.
If you do not want to download, you can still check back the file in Vault Explorer Client.
Hope that helps!
hi Mr. kumar,
before i change working folder from C:\document and setting to C:\,
so i do can't get/check out command (any mention "you already check out in other directory"
than i rechange working folder to C:\document and setting but can't
You can Undo Check out (without Replacing the working copy), then Check out without Overwriting the Local copy. Now you should be able to Check-in.
Let me know how that goes.
