Vault General Discussion
iranovitas
Message 1 of 5 (212 Views)
check out file (excel) than deleted, can check in back?
212 Views, 4 Replies
06-27-2012 07:02 PM
how if i check out file (excel) than in working folder the file is deleted,
can i check in back that file ?
or do you have solusion to restore that file to the vault?
Thank you very much before,
You can Undo Check out (without Replacing the working copy), then Check out without Overwriting the Local copy. Now you should be able to Check-in.
Let me know how that goes.
Employee
Senthil-Autodesk
Message 2 of 5 (210 Views)
Re: check out file (excel) than deleted, can check in back?
06-27-2012 07:12 PM in reply to: iranovitas
Even if you delete the file in local disk, the file still should be in Vault. So you should be able to download the file again using Get/Check out command from Vault Client. Once you download the file, you can again modify,save and check-in.
If you do not want to download, you can still check back the file in Vault Explorer Client.
Hope that helps!
Senthil Kumar
Vault QA Team
Be sure to check out the Vault Help!
iranovitas
Message 3 of 5 (206 Views)
06-27-2012 07:51 PM in reply to: Senthil-Autodesk
hi Mr. kumar,
before i change working folder from C:\document and setting to C:\,
so i do can't  get/check out command (any mention "you already check out in other directory"
than i rechange working folder to C:\document and setting but can't
Employee
Senthil-Autodesk
Message 4 of 5 (203 Views)
06-27-2012 09:38 PM in reply to: iranovitas
Senthil Kumar
Vault QA Team
iranovitas
Message 5 of 5 (200 Views)
06-27-2012 09:58 PM in reply to: Senthil-Autodesk
Hi Mr. Kumar,
Ok, that's alright,
Thank you very much,
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
