Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
check out file (excel) than deleted, can check in back?
4 REPLIES 4
iranovitas
414 Views, 4 Replies
how if i check out file (excel) than in working folder the file is deleted,
can i check in back that file ?
or do you have solusion to restore that file to the vault?
Thank you very much before,
4 REPLIES 4
Senthil_Kumar
in reply to: iranovitas
Even if you delete the file in local disk, the file still should be in Vault. So you should be able to download the file again using Get/Check out command from Vault Client. Once you download the file, you can again modify,save and check-in.
If you do not want to download, you can still check back the file in Vault Explorer Client.
Hope that helps!
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
iranovitas
in reply to: Senthil_Kumar
hi Mr. kumar,
before i change working folder from C:\document and setting to C:\,
so i do can't  get/check out command (any mention "you already check out in other directory"
than i rechange working folder to C:\document and setting but can't
Senthil_Kumar
You can Undo Check out (without Replacing the working copy), then Check out without Overwriting the Local copy. Now you should be able to Check-in.
Let me know how that goes.
Senthil Kumar
Autodesk, Inc.
iranovitas
Hi Mr. Kumar,
Ok, that's alright,
Thank you very much,
