Hi Warren,
This is to clarify the issues that you have been encountering with Check In action.
1. When you check in DWG/IDW with DWF, you are seeing check in progress bar that shows 100% and does not get closed.
2. The server reports time-out while working with Inventor DWG
The good news is that we found the cause for issue 2 and we are in the process of supplying a hotfix.
Regarding issue 1, it has been escalated to the management to have it fixed soon.
We sincerely apologize for the inconvenience caused. If you have any further questions with regards to this please feel free to email madhanagopal DOT t AT autodesk DOT com.
Thank you for your understanding.
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
