Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Check in of .idw causes crash and corrupt file
2 REPLIES 2
219 Views, 2 Replies
Hi
Working in a small company, doing design work for a big project.
Multiple users from several companies are connected, collaborating using vault over vpn (sonic wall)
Works good with all files except with .idw drawings, which during check in halts and crashes most of the time.
The problem seems to be more frequent during work hours, which points to it beeing Bandwith / latency related?
The problem is well known in all these companies working on the project but no one has found a solution.
Ofcoarse no one uses visual attachment etc stuff like that.
Any suggestions would be appreciated
2 REPLIES 2
BLHDrafting
Wild arse guess. Assuming bandwith is the issue are you creating visualisation files (DWF's) during checkin? If yes try turning them off and checkin the IDW. Personally never had an issue but I am not doing it over VPN.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
Please read, 2nd line from the bottom again
No one uses visual attachment
But anyways thank you for replying.Smiley Happy
