any help with this check in error (attached)?
Very annoying. I checked every part, every drawing, i cannot see what is the problem?
Is there any log file that i can see which files are problematic?
Thanks.
When you save, do you select "Yes to All"? It may be that there are files that need to be migrated to the current release of your software. Files that need to be migrated cannot be vaulted and will give an error like this.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Try using the Filter - Show Modified Files Only- from Vault browser to isolate the file.
