is there a possiblity to show the size of imported data?
So i can find "the big files" and if possible eliminate unused/unimportant ones.
A hint to big files could be the datasize of the folder, but i can t see the foldersize within the form.
Any suggestions?
Greetings
christian
Right mouse click on the cells located in the main window pane and select Customize View. Select Fields and scroll down to you locate the field called File Size. Add it to the list and reorder as required.
Yes , that works for files, but what about Folders? For me it is interesting to see where in our structure space can be saved or where do we need more space?!
Christian
I know this is 5 Years too late, but i figured i'd give a solution for anyone else who goes looking
You can find the size of a folder in Autodesk Vault by using 1 of 2 methods (that i know of):
1. This is the simplest method
Simply right click on the folder and click "GET"
When vault goes to download the folder and its contents to your local machine, it will tell you how large it is
2. Slightly more complicated method
- Add the "File Size" column to your working area in vault
- Open the folder in question and search for "." (without quotes) This will bring up every sub folder and file
- Make sure you have all the files visible (if there is a large amount of files, you will have to click the "More" button at the bottom right hand corner of the vault working area. Keep clicking it untill all files are visible)
- Now click on File, Export and save the spreadsheet somewhere
- Open the spreadsheet you just created and delete everything except for the file sizes
- use Excel's "Sum()" Function to make a total of the file sizes (This total will be in Bytes)
- Note, if the Sum function doesn't work it's because the numbers are stored as text in each cell, to fix this, select all the cells that contain file sizes and if you scroll to the bottom of the cells you should see an exclamation mark next to the cells. Click it and select "Convert to Number". They should all convert to number cells and the Sum function should work.
Hope this helps
Hi Travis,
thank you for your solution!
i used the first "easy" method and it worked quite well.
I havent tried the second method, our Vault is getting pretty big and i didnt really feel like clicking "More" for 5 minutes.
No such thing as 5 years to late!
- Mees
Another variation on (2) would be to do an advanced search on File Size > {some criteria} .
This would provide a list of files you might specifically care about.
Paul
