Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Changing Categories/Lifecycles
1 REPLY 1
CelticDesignServices
253 Views, 1 Reply
Just wondering out loud here on what I might see for results to the following:
What happens or what can I expect to see happen to a part that is currently stored in Vault Workgroups with a Category and thus Lifecycle that will either change or deleted altogether?
I can figure simply changing the part's Category and thus Lifecycle to a new one is not an issue, but if that Category/Lifecycle is deleted, what happens to the part in Vault? Does it simply revert to the Default, Unassigned category?
What I'm looking at is completely revising the client's Categories and Lifecycles to better suit them.
Just wondering if I should make all the new Categories/Lifecycles first, then manually change the files or if they revert to Default, just let that happen and fix as needed?
Thoughts?
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
1 REPLY 1
You can't delete a category or lifecycle that is currently in use.  Before you can delete it, you must first change the category or lifecycle of the parts to something else.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
