Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Change Index automatic update timing
2 REPLIES 2
aguitton116
327 Views, 2 Replies
Hi, is there any way to change the automatic update of the vault index which occurs every 20 minutes to a shorter time ?
2 REPLIES 2
paul.gunn
in reply to: aguitton116
Hi ,
This is controlled in web.config:       <add key="FullcontentIndexing" value="0:20:0"/>
The value 20 [minutes] could be reduced to a shorter period.
However you would need to disable full content indexing in ADMS console [and then reenable it] in order to consume to changes to this value. Please note that doing this will entail a full rebuild of the content index [which could take some time depending on how many files you have].
Paul
aguitton116
in reply to: paul.gunn
Thanks a lot !
