I've upgraded my Vault Workgroup Server from 2013 to 2014. Now, only 1 custom library is available from CC in Inv 2014. Everything seems to work as before with 2012 and 2013.
In my list of libraries in ADMS, I would expect to see a list additional "AI2014_Inventor xxxxx" libraries - but I don't.
Any ideas? THANKS!
Any ideas? THANKS!
Did you right click on Libraries and select "Attach Library"? It should bring up a dialog with basic and advanced tabs. The advanced will let you navigate to the location where your library databases are located. Can you post a screen shot of your ADMS screen with "Libraries" expanded? I'm looking at 2013 so my screens may look different.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Here is my libraries list from ADMS 2014. I would have expected additional libraries to be listed "AI2014_Inventor......"
Have you upgraded to Inventor 2014 as well? If so, did you check during the install to make sure that all CC libraries that you wanted were checked? They are not all checked by default. I've seen plenty of posts in the Inventor forum about this, all it takes is to amend your install to add the missing libraries.
Chris Benner
I have upgraded to Inventor 2014. Actually I have 2012, 2013 and 2014 installed.
The desktop content was installed when I installed Inventor 2014. However, I want to use Vault.
Can't I migrate my 2013 Libraries to use in 2014?
