We have created a templates folder and inserted a couple of template files in this folder.
However, when activating the new standard file function we cannot see these templates.
There is text: "Add template folders and files first"?
Thanks in advance
Paul
Solved by Senthil_Kumar. Go to Solution.
Please ensure that the Vault folder path for the templates match with the folder paths mentioned in the XAML file. They should match in order to use the templates.
Hi Paul,
You can refer the following link on how the Template folders should be created.
http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-E00DEDB5-1A3D-435A-8FCC-36BA447CFEB8
For AutoCAD the path should be like this
$\Templates\AutoCAD</TemplatePath>
Please try this and let me know if this doesn't help.
