Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Cannot see data standard template files
3 REPLIES 3
Esky99!
424 Views, 3 Replies
We have created a templates folder and inserted a couple of template files in this folder.
However, when activating the new standard file function we cannot see these templates.
There is text: "Add template folders and files first"?
Thanks in advance
Paul
3 REPLIES 3
Senthil_Kumar
in reply to: Esky99!
Please ensure that the Vault folder path for the templates match with the folder paths mentioned in the XAML file. They should match in order to use the templates.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Esky99!
in reply to: Senthil_Kumar
Hi Senthil
I haven't modified the XAML files path. Isnt the default location meant to be a Templates folder under the root location?
I added a folder in vault directly under the root directory called: Templates.
I'm not sure on why it is not seeing these template files.
I tried editing the XAML file in Visual Studio and am receiving errors.
[cid:image003.jpg@01CFBAC1.C32B8F20]
Regards
Paul Coleman | CAD/Systems Administrator
537 Lake Road Argenton NSW 2284
PO Box 35 Boolaroo NSW 2284
m: 0404490426 | p: +61 2 4902 5010 | f: +61 2 4902 5066
[cid:image004.jpg@01CFBAC1.C32B8F20]
________________________________
This email and its attachments may be confidential and are intended solely for the use of the individual or entity to whom it is addressed. Any views or opinions expressed in this email are solely those of the author and do not necessarily represent those of "KopexWaratah".
If you are not the intended recipient of this email and have received it in error you must not copy or disclose its contents and must delete the email message and any attchments.
Please note that the recipient should check this email and any attachments for the presence of viruses "KopexWaratah" accepts no liability for any damage caused by any virus transmitted by this email.
Senthil_Kumar
Hi Paul,
You can refer the following link on how the Template folders should be created.
http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-E00DEDB5-1A3D-435A-8FCC-36BA447CFEB8
For AutoCAD the path should be like this
 $\Templates\AutoCAD</TemplatePath>
Please try this and let me know if this doesn't help.
Senthil Kumar
Autodesk, Inc.
