I'm trying to apply the above hotfix on our workstations. On the only Win7-64b workstation the hotfix won't install. The progress bar goes to 80% and then progress stops, keeping the window open and must kill the process to go away.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19857773&linkID=9261341
There may be something other than Windows 7 going on here.
What are your versions and bitnesses (64 or 32) of these applications:
- Any CAD applications (Inventor, ACAD, etc.)
- Microsoft Office
Copy the hotfix to your local machine, select the hotfix and "Run as administrator". I used to have the same experience, but finally get resolved by the solution above. Hope this is helpful.
-Erik
