Hello need help,
i updated from 2014 to 2015. With logiing In to ADMS 2015 i get an error -Password or user wrong-. I didn't change any passwords, the user was in 2014 the standard- User 'Admininstrator'- account without any password.
How can I fix this?
Thank's for help.
Solved by m.hermann. Go to Solution.
@m.hermann wrote:
Hello need help,
How can I fix this?
Thank's for help.
This may be a bad question, but are you sure you're typing it properly? I only ask because in your post Administrator is misspelled.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
yes the login Name was correct. I deleted the knowledgeVaultMaster in Sql (there was a former vault instance) and did a reinstall, that works.
