When I have added some Properties for ECO,I can't see them in a new ECO.
Is it a Bug?How can I fix it?
Solved by yuhui.zhang. Go to Solution.
Thank you for your posting.
The properties defined in your first image is for 'Link Properties' which will be linked with items or files in the records tab (second tab). see Link Properties section in wiki page.
If you want to define properties for ECO itself on General tab, you could go to New User Defined Properties from Behaviors tab-> Properties.. button-> Properties Definition dialog and associate it with ECO entity. see below screenshot:
Then you will get this property on ECO first tab and be able to edit its value.
Hope it helps.
