Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Can't See ECO Properties
2 REPLIES 2
jiang_xingbo
349 Views, 2 Replies
When I have added some  Properties for ECO,I can't see them in a new ECO.
Is it a Bug?How can I fix it?
2 REPLIES 2
yuhui.zhang
in reply to: jiang_xingbo
Thank you for your posting.
The properties defined in your first image is for 'Link Properties' which will be linked with items or files in the records tab (second  tab). see Link Properties section in wiki page.
If you want to define properties for ECO itself on General tab, you could go to New User Defined Properties from Behaviors tab-> Properties.. button-> Properties Definition dialog and associate it with ECO entity. see below screenshot:
Then you will get this property on ECO first tab and be able to edit its value.
Hope it helps.
Fay Zhang
Software QA Engineer
Data Management
Be sure to check out the Vault Help Wiki!
jiang_xingbo
in reply to: yuhui.zhang
我明白了,谢谢!
