Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Can't "Restore Down" Vault Explorer Window
2 REPLIES 2
karthur1
194 Views, 2 Replies
I want to resize my Vault Explorer window so I click the "restore down" icon in the upper right corner. Instead of restoring down the window, it minimizes the window all the way down to the task bar. There is no way I can change the size of the window.
I have a dual monitor setup and I am trying to move the VE to the other monitor.
VE 2010
2 REPLIES 2
polo.zhenshi
in reply to: karthur1
Thanks for your feedback. Unfortunately, we never met such issue before and cannot reproduce it. Could you check: after "restore down", right click the button in the tray to see whether the move or size command available? OR try right click the Taskbar and select Cascade or Tile Windows.
Polo
karthur1
If I right-clicked on the task in the bar, the only thing that was available was the"maximize" command. I have got it working correctly now. To get it working I deleted I closed VE and then deleted the folder at the path
"C:\Users\KArthur\AppData\Roaming\Autodesk\Autodesk Vault 2010".
Works great now.
